Lincoln welder w/ 4 cylinder engine and Bosh magneto
Walt in Jaxn Tn
04-15-2003 20:38:24
Friend of mine has a Lincoln welder that will not start cause it has no spark. It has what looks like a Hercules 4 cyl water cooled flathead, and does have a flange mount american bosh magneto. 2 questions, first, who made the engine? 2nd is the magneto a gear driven or a lug driven impulse? We'd like to take the magneto off to check the points. there is a governor bolted on the other side of a thin timing gear housing. the same bolts that hold the magneto on, hold the governor on too!And of course, we appreciate any help.
PD
04-17-2003 07:15:22
 Re: Lincoln welder w/ 4 cylinder engine and Bosh magneto in reply to Walt in Jaxn Tn., 04-15-2003 20:38:24
The engine on your Lincoln welder is likely a Continental, either F-140 or F-162. The bolts for the mag and governor are shared in commom. If you remove the bolts on the mag, there should not be a concern about the governor. IF memory serves, the mag is impulse coupled. Good luck. Regards..... ..P
