Ready Heater
Don
09-01-1998 14:26:43
I have a propane Ready Heater.
After about 10 minutes of running the heat shuts
off. The fan continues to run but it seems the
propane stops flowing. It will not restart right away. Normaly takes 5 minutes to restart it.
Any sugestions? Thanks Don
Bob
09-03-1998 16:08:53
 Re: Ready Heater in reply to Don, 09-01-1998 14:26:43
: I have a propane Ready Heater.
: After about 10 minutes of running the heat shuts
: off. The fan continues to run but it seems the
: propane stops flowing. It will not restart right : away. Normaly takes 5 minutes to restart it.
: Any sugestions? Thanks Don
Don -
My guess is there's an overtemp thermostat inside your heater that's interrupting the signal to propane valve. Purpose of this t'stat is to cut off the propane and prevent overheating should the fan fail.
Check for either a bad t'stat or (unlikely) insufficient airflow from the fan.
Bob
Larry Henkens
03-07-2000 10:44:05
 Re: Re: Ready Heater in reply to Bob, 09-03-1998 16:08:53
I have a ready heater (kerosene)It will not restart even when I use the the reset button. It runs but will not ignite. should I have it serviced? any suggestions?
