Crow's foot wrenches
mwkellner
04-14-2003 11:16:52
OK I'm and idiot. what are crow's foot wrenches used for? I think that I am using the right name. They look like and open end wrench with no handle. There is just a hole there to fit a socket in I quess. I can't think of an advantage. Please fill me in on this. Thanks -- Martin
Foz
04-15-2003 21:38:23
 Re: crow's foot wrenches in reply to mwkellner, 04-14-2003 11:16:52
I boughtna set of crows foot tubing wrenches the other day for useing on hydraulic lines . they really are worth their extra cost when the connections are hard to get to. lotta times the fitting is way back under a shroud or brace and it saves a lot of time when you just ad another extension and can reach it and leave the shrouds on .
Al in BC
04-14-2003 20:38:09
As a retired mechanic I used them with an extention and ratchet to get under valve rocker train to retorque head bolts. You therefore don't have to pull the rockers to torque the head for the second time after you have brought the head to temperature. My 2 cents
Al.
Slowpoke
04-17-2003 00:49:24
 Re: Re: crow's foot wrenches in reply to Al in BC, 04-14-2003 20:38:09
Anybody ever seen a set with box end configuration?
Just like to know.
DaveCA
04-19-2003 06:36:18
 Re: Re: Re: crow's foot wrenches in reply to Slowpoke, 04-17-2003 00:49:24
Don't know how short you need, but torque adapter comes to mind, good for intake manifolds on V engines.
John Garner
04-18-2003 11:41:35
Slowpoke --
Snap-On and Bonney used to make box-end crow's foot wrenches commercially, they and others made them for the Government.
John
charlie
04-14-2003 18:12:27
an absolute must for changing broken hydraulic hoses on back hoes.
DumOleBob
04-14-2003 17:28:28
I use mine to actually wrench the feet off dead crows. Works like a charm! And, are them crow's feet ever good fried with a little garlic & some gritz on the side..... Sorru, I'm nuts & just could not resist! Never knew what they were for till you asked. So kill me!
Dave
04-15-2003 05:19:29
 Re: Re: crow's foot wrenches in reply to DumOleBob, 04-14-2003 17:28:28
Hahahaha.
I eat a lot o crow and have a complete set.
Jerry L AZ
04-14-2003 18:02:26
In the Navy we had a wrench that looked like a c with a handle on it we called a crows foot used to opean or close large valves ..... ..Jer
Ludwig
04-14-2003 16:01:21
'Bout the only thing I know of to take a carb off a rotax single cyl 2stroke motor. Even then you have to grind the back where the socket goes in just as thin as you dare.
Very handy, but not something I'd buy in a set. I've collected 2 so far. As I need more I'll buy them.
F14
04-14-2003 13:39:38
A socket extension fits in the square hole, give you an open end wrench at right angles to the socket extension.
Quite handy for getting into tight places.
Gary in IL
04-14-2003 14:34:08
 Re: Re: crow's foot wrenches in reply to F14, 04-14-2003 13:39:38
even handier..... .crow's foot LINE wrenches for those impossible-to-get-to transmission cooler line fittings..... .
RB/CT
04-14-2003 17:35:12
 Re: Re: Re: crow's foot wrenches in reply to Gary in IL, 04-14-2003 14:34:08
They are a handy tool to have both metric and sae. Quite expensive, I bought the imported ones, and am quite pleased. Anybody know what a Crowbar is. It's a place that the crows go to drink.
big fred
04-15-2003 09:28:43
 Re: Re: Re: Re: crow's foot wrenches in reply to RB/CT, 04-14-2003 17:35:12
Unless it's capitalized as in Crow Bar. In that case it's an organization of crow attorneys.
RB/CT
04-14-2003 17:35:11
