Making gin poles
trevor
04-12-2003 23:08:58
I am in the process of moving a log building-one log at a time. The logs are really dry- 14 feet long and 10"diameter. Have been thinking of making gin poles for my Ford Ranger 4x4. I already have a 4000lb warn portable winch. Could use some advise on makinghte gin poles themselves. Anybody ahve any info on them.
Slowpoke
04-17-2003 00:17:47
 Re: making gin poles in reply to trevor, 04-12-2003 23:08:58
I always thought a gin pole was a tall verticle pole held buy guy wires, with a second pole attatched to the base of the verticle pole and able to swivel in a horizontal and verticle direction, controlled by cables from the top of the verticle pole. Usually used in the lumber and construction industries in years past.
mj
04-13-2003 12:14:51
third party image
I used some old drill stem and 3" inch channel. The poles don't come together at the top; I left enough space so that an extension ladder can be fastened on for tree-trimming, etc. Boom is supported by 1/4" cable and will lift more than the Oliver can without the front wheels coming up. I used it to set 16' treated 6X6s and it handled them fine. The pipes are about 10' long and use tabs welded to the drawbar with 5/8 bolts as a hinge for changing the angle of poles. Winch is a Warn that's double-blocked in the photo.
