Log Splitter
phil
04-11-2003 08:38:18
My summer project(one of them) will be a log splitter. I am trying to decide wether I should use a hyd pump on the PTO or use a separate gas motor(5 horse or better) I dont think that the hydraulics on the tractor would be enough on their own. hence the separate pump on the PTO. the tractor is a MM 335 utility. any suggestions or opinions? Any help would be appreciated, Thanks, Phil
Dave_Id
04-12-2003 18:19:05
 Re: Log Splitter in reply to phil, 04-11-2003 08:38:18
Phil, I've made five tow behind splitters, using Rambler spindles, then finally started to reallize that by the time I bought the materials, got an engine for it, and purchased other components, I could have bought a new one from Northern already assembled for about the same price. The one I'm using now is a 3 point setup from Northern that I paid around $450 for. It is an excellent unit that I run off the tractor hydraulics.
Ludwig
04-11-2003 15:40:43
I'm on the other side from Ron. I have a hard enough time keeping the tractor going, last thing I need is another engine to keep running. I'd run mine off the tractor.
The only thing is that a little 5hp motor would use alot less fuel. A little diesel engine would even be better.
Maybe if you were really clever you could build it so the engine could also power a generator, double duty from one engine.
Ron from IL
04-11-2003 10:37:03
Phil,
If you use a separate motor, it'll free up your tractor for other things. The reason I say this is that a few years ago, I bought a chipper/shredder that works off the three point hitch/PTO of my 2N Ford. It works fine, but I wish now that I'd gotten one with an independent engine.
Good Luck!
Ron
