Cracked tires
Shank
04-09-2003 17:26:20
Is there A method for filling cracks in rear tractor tires?Exclent tred,lots of cracks. Thanks in advance, Shank.
BlueLite
04-11-2003 11:20:23
 Re: Cracked tires in reply to Shank, 04-09-2003 17:26:20
"Goop" body trim glue is real tough when dry and works fine on sidewall cracks. Clean out good with naptha and let dry before applying. If you don't mind clear glue in the joint it'll work.
Someone on the forum a while back said they used the black window sealant that seals windshields before replacing glass.
BlueLite
04-11-2003 11:20:11
Bus Driver
04-10-2003 16:59:21
I have not tried this- and know no one who has- but I suspect that Devcon Flexane 80 Putty (Grainger 5A459) and/or Devcon Fast Cure Rubber Repair Urethane Putty ( Grainger 4TT48) would both work well. They are EXPENSIVE. I do know that a commercial tire shop near here repairs the forklift tires that are used to unload the trailers on the Truck/trains- BIG tires, sometimes get ripped open by spikes, etc. They use some sort of compound which I suspect is one of these- but they won't talk about it. If anyone tries it, please let us know the results.
KEG
04-09-2003 19:44:37
shank,
Do what Bigdog recommends. Miller has a tire paint product that really works well. Used it on a '44 B with old tires and it made them look real good.
KEG
Bigdog
04-09-2003 18:16:11
Check with Miller Tire. I believe they have what you are looking for.
