Hi Again: Sounds like you would have plenty to run a true 5hp, and maybe even a bit bigger. We have a 100 A 3 phase service into our shop and can test up to a 40hp compressor. I guess you'll have to do a little research to see if you have enough spare service to run it, but it sounds like you do. An electrician would be able to tell you that, maybe even over the phone. I doubt every last machine you have runs at 100% all the time so there is probably more reserve than you think.I'd be tempted to put in the biggest compressor I could run/afford. You never know when your excellent work will result in a flood of new customers and a need to expand. Go to www.championpneumatic.com. Look for the specs on the R Series splash lubricated units. The models are designated as follows H or V for horizontal or vertical tanks, R for R series pump, the number next is the hp, and the last number is the size of the tank in gallons, divided by 10. So, an HR5-80 would be a horizontal 5hp splash lubricated pump on an 80 gallon tank. Notice the rpm's that the pumps are running at. Nice and slow! Also notice however, that the 5hp R15 pump is also used as an entry level 7.5 hp pump as well, so everyone does it to some extent. The next pump in the line is a v-4 unit, which is really a 10hp pump, an R-30, which is a bit expensive to build up as a slow running 7.5hp unit. Even at 7.5 hp, though,the R-15 is still running much slower than most cheapy 5hp compressors. Note, you will need Adobe Acrobat reader to view these pages. Try going to the spec sheets and see if they give you Adobe right there if you don't have it.I am by no means saying either, that there aren't excellent machines available from Quincy, IR, Curtis, Saylor Beall or any number of other companies in the US. I do not work for Champion. I do know that they work well and are priced reasonably. For heavier duty service, you can also go to a pressure lubed PL series machine, but they are quite a bit more money. Do some research on machines from other companies to price compare. By the way, you will need a magnetic starter for a real 5hp machine, and probaly a disconnect or breaker installed, so remember to budget for these items as well. If you are going to put the unit into a seperate shed. Make sure there is adequate airflow to evacuate the hot air when the compressor is working. Always exhaust air form the shed, do not blow air in. All you will do is slightly pressurize the shed and have a stagnant pool of hot air inside there. It is a common error when people do their own ventilation. There is often an auxiliary contact on the side of many magnetic starters that can be used to control other devices when the starter is activated. You could perhaps wire an exhaust fan to this that automatically starts with the compressor, and shuts off when it does. Alternately, you could have the fan thermostatically controlled. Position the fan in the room so it drags the hot air off the pump in co-operation with the natural airflow from the blades on the flywheel. That is, don't have the fan sucking air from the front of the pump, when the flywheel blades are trying to blow air back over the pump. Ensuring that the compressor is turning the proper way is crucial! We recently had a compressor fail after only 2 months because the owner installed it himself and had the rotation backwards. It ran too hot and seized. Be sure to put a filter on any opening that admits cooling air into the shed, something like a furnace filter to help keep the operating environment clean. Pollen and such can make a real mess when mixed with even the slightest oil leak. Also do not forget to leave enough room around the entire compressor unit to allow for any service or repairs. This is my own pet peeve! I have once been forced to stand on a wooden platform about 3 inces larger all around than a 60 gal DeVilbiss compressor that was dangling from a ceiling by 4 3/8 ready rods. And not solid rods either, about 4 rods per corner, connected by coupling nuts, bolted to the roof girders. Swinging away like Tarzan. I wondered if any of those rods were in by a half a thread!:-). Resist the temptation to put a compressor up high. Out of sight, out of mind. And when it eventually fails because of no oil changes for 8 years, it is some poor schmuck like me who has to put on the moutaineering gear and go and get it! I always laugh when I go into a shop and see the amount of work put into a platform to raise a compressor up from floor level. Why? To save floor space. Funny, there never seems to be anything under the compressor..... .. It is hard climbing a ladder with 80lbs of tools, and a real workout to go back down every 5 minutes to get the tool you forgot last trip! Be sure to allow for some kind of easy access to drain condensate from the tank as well. I have seen tanks with as much as 20 gal of water in them because they were never drained. Tanks can rust through quickly if neglected. Something as simple as putting the compressor on a pallet can give you a few extra inches of clearance for this task. If I were doing this install, I would put in a timed electic auto drain. They aren't terribly expensive and do a good job. Drain the condensate outside of the shed. Oily water ruins wooden floors. Remember that it is not always summer as well! You should put some form of heating device in there in the winter, as compressors do not relly like operating at freezing or below freezing temperature. Drain lines can freeze up as well,and due to the start-stop nature of compressor operation, pumps operating with heavy, thick oil will wear quickly, especially wrist pins and bushings. Don't use uncovered fiberglass insulation, as it tends to fall apart and do the same thing I warned you about with pollen, a real mess. Fiberglass covered in some kind of vapor barrier or styrofoam would be best. Allow for some kind of disconnct for the cooling fan as well, a simple light switch would do. Well, that is about all I can think of right now. Now that I have spent all of your money, you better get busy welding!
