PD
04-09-2003 08:09:19
Re: Husky air compressors in reply to Bill (NJ), 04-08-2003 16:23:46
I used to work at Home Depot and I sold these compressors. If you look closely at the sticker on the tank, it says "develops" 7 horsepower. If you also notice the sticker, it says that it develops approximately 6 CFM "free air" at 40 PSI. Now look on the motor nameplate. When the horsepower is listed, it says "SPL". That simply means that the motor is purpose-built for that unit and, in reality, the motor is a "real" 1 1/2 or 2 horsepower. The way companies are allowed to market air compressors is misleading, IMHO. Think about it. A "real" 7 horsepower motor will cost almost 500 dollars. How can they sell a "real" 7 horse compressor, complete, for $399? Husky compressors are made by Emerson Electric in St. Louis. As compressors go, they are fine for light duty, airing up tires, etc. A bead blast cabinet, and most air tools, require a minimum of 10 CFM at 90 psi. Home Depot sells a larger Husky compressor, with a real 7.5 horsepower motor, mag starter, 2 cylinder, 2 stage, 80 gallon tank for $1599. This model is a good compressor that will more than handle what you want to do. I realize that money is always an issue, but, again in my opinion and experience, you will be dissatisfied with the smaller compressor for you needs. Good luck with whatever you decide. Regards..... ...P
