BE-GE pump oil seal
Rick from Paso
04-06-2003 18:08:29
My front mounted Be-Ge hydraulic pump shaft seal is leaking pretty badly. Does anyone know where to get a seal for this puppy? I pulled the existing seal and it has 472452-X60 stamped on it, NAPA has no cross reference. The pump ID plate is pretty buggered up, I can make out model ??11110-XA group 853000KS 2000 PSI, 2400 RPM Max. This is mounted on my tired old Case 310B tlb. Thanks for your help.
John
04-17-2003 13:41:29
 Re: BE-GE pump oil seal in reply to Rick from Paso, 04-06-2003 18:08:29
Rick: Baum Hydraulics seems to have every size seal made. WWW.BAUMTOOLS.COM
Mike
04-07-2003 17:44:31
If you just pulled the outermost seal on the shaft, this should just be a dirt seal. There should be a seal or seal and backup ring located in the pump housing. Possibly your best bet would be a hydraulic shop, where they could match up the seals etc, that you need.
