Pressure regulator for air compressor
chris smith
04-06-2003 12:57:12
The regulator doeasn't work on my recently acquired air compressor. If you turn the knob out the air bleeds out the bleed hole continually.. tighten it down and it quits.. I took it apart and here is what i found. There is a needle like valve stickiing up from the base, looks to be spring loaded. Then in the top part which is what unscrewed, there is a plastic disk with an o-ring, then a spring then a metal disk which is pressed on as you screw in the handle. Any ideas how to fix this?? I tried oiling it and it still don't work. I can live with it not working, but it would be nice if it worked..
Thanks guys.. Chris
David
04-08-2003 12:32:54
 Re: Pressure regulator for air compressor in reply to chris smith, 04-06-2003 12:57:12
I also have seen them installed with the airflow going in the wrong direction. Is there any directional indication on the body of the unit?
T_Bone
04-07-2003 22:19:46
Hi Chris,
This regulator is differential pressure regulator. P#1 is line pressure and P#2 is the reduced pressure.
The needle valve seats P#1. The plastic disc with O-ring is P#2 diaphram and is the seal. Setting the P#2 puts pressure on the metal disc pushing on the spring and that apply's differential pressure to seat the neddle valve. As P#2 is reduced this allows the needle valve to open allowing flow from P#1. As the pressure builds in P#2 then this apply's pressure to the disc again shutting off the needle valve of P#1 supply.
With the o-ring leaking is whats letting air bleed from the hole. Could be a bad o-ring or a scored bore. This is also keeping the regulator function from working.
T_Bone
Jack
04-06-2003 17:48:09
Try a new regulator--they're probably cheaper than fooling with the old one. Harborfreight, Home Depot, Lowe's
Central Minnesota
04-06-2003 16:20:12
Are you sure that the airflow was the right direction through the regulator. I've seen some do what you described when installed backwards. Just guessing.
chris smith
04-07-2003 15:15:19
 Re: Re: Pressure regulator for air compressor in reply to Central Minnesota, 04-06-2003 16:20:12
The regulator is built in. Can't easily replace it.. Any more ideas??
Later.
