Welding cast drive gear on rake. Can it be done?
Bob G - WA
04-03-2003 07:42:21
I have been looking for a side delivery rake for quite a while and final found a David Bradley. It is in very good condition except it has a broken drive gear in the gear box. It is split length-wise. Is it possible to have these welded and last for any length of time. I will only be raking 5 to 10 acres per year.
Thanks,
Bob
jake
04-05-2003 09:04:24
 Re: Welding cast drive gear on rake. Can it be done? in reply to Bob G - WA, 04-03-2003 07:42:21
If the gear is small enough I would braze it. Apply flux, wire the part together, heat till red apply brazing rod w/flux[bronze rod melts at lower temp]. After the brazing put the gear in dry sand and let it cool slowly, the joint will be stonger than the original part. Good luck
T_Bone
04-04-2003 05:48:06
Hi Bob,
If the gear is in an area where it's easy to get to then I would have it welded. If it was difficult to tear apart then I would look at a replacement gear as sucess of welding repair might not work as depending on who does the repair and the cost. If your going to weld it yourself then whats your time worth? I personally would weld it providing I didn't see anything else wrong.
I'm with the other posters, why did it break to begin with? No/wrong type of shear pin? Underdesigned? Bad casting?
T_Bone
george md
04-03-2003 22:11:59
Bob , Successful repair is possible using acetylene torch and bare cast iron rod with flux , repair will
last as well as new gear . As ray said , find out
what caused the failure .
george
Bill 52 8n
04-03-2003 21:34:29
I would doubt welding would hold the gear together very long. The higher carbon content in the gear gives it poor weldability. Is it a standard gear that you could get somewhere else?
Bill
Ray,IN
04-03-2003 19:31:52
The experts can reply on the weld reliability issue. I would first be concerned as to what caused the gear to break. If something mechanical caused the broken gear it may happen again-soon after the repair.
