Wheel spacers
Jerry L a
04-02-2003 16:01:12
I want to put duals on my 8N, I have found spacers for a ferguson, the ferguson lugs are 9/16 and the 8N lugs are 5/8 the center discs look the same, question are the bolt hole circle the same, and can the spacers be redrilled to 5/8 thanks....Jer
george md
04-03-2003 22:31:51
 Re: wheel spacers in reply to Jerry L az, 04-02-2003 16:01:12
Jerry,
I grew up with an 8N with daul wheels, duals
almost make a tractor out of an 8N. Lugs are near
3 inches long , threaded internaly on one end to
replace the nut one the inner wheel and threaded
externally on other end to use the nut from the
inner wheel to hold outer wheel. Body diameter is
about 1 1/8 and has 1 1/16 hex for tightening
the lug. Spacer is bored to fit neatly over the
lugs and is about 1 1/2 inches thick. I had a set
laying around the shop for the last 40 years , but
now I can't find them . We traded the 8N on a 300
case about 1959 , boy was that a step up . I'll
look out in the yard tomarrow , possibly I can
find them .
george
Jerry L az
04-05-2003 01:46:51
 Re: Re: wheel spacers in reply to george md, 04-03-2003 22:31:51
George, hey thanks for the post let me know if you find them, would you part with them? if you do &if they are for sale,email me ok ..... ..Jer
T_Bone
04-03-2003 00:22:33
Hi Jerry,
Take a piece of construction paper and lay over the stud holes, then use a ball pene hammer to "gently" tap on the paper thats over the hole. This will cut a sharp hole that is the exact bolt patteren then fit that over the stud layout to see a match up or not. The only difference should be the bolt diameter if it's a match.
I've made alot of gaskets this way and it's accurate.
T_Bone
Jerry L az
04-03-2003 05:07:21
 Re: Re: wheel spacers in reply to T_Bone, 04-03-2003 00:22:33
thanks, T-Bone, I don't have the spacers in my possession, I was hopeing to find out before I bought them. any way I finally found out that they will work, same bolt hole circle..... .Jer
