Cracked block
Fred
04-02-2003 13:43:44
Any new products on the market to repair A cracked block?
TimC
04-04-2003 06:34:23
 Re: Cracked block in reply to Fred, 04-02-2003 13:43:44
Stiching pins.
Gary-Miss
04-02-2003 17:53:15
Is this an "A" Farmall or JD? On an A Farmall, they usually crack on the outside and at the top. The sleeve is the sealing surface on top, so, usually, if the head is also cracked, a replacement head will fix that. On the side, clean it good and use epoxy. It has always worked well for me.
hjp
04-02-2003 17:49:00
there is a welding process called SPRAYING it uses iron powder does an excellent job
