Trouble running
randy
03-29-2003 19:17:09
20hp onan motor wheel horse,will not run unless you have the choke closed almost all the way or the engine also ,when you put in gear or wants to raise up or down.please help .pretty new at this,having fun
JoeK
03-30-2003 05:54:11
 Re: trouble running in reply to randy, 03-29-2003 19:17:09
Starving on demand,try opening main jet on carb a bit.
fuel delivery problem?
check filters
clean fuel bowl on carb
weak fuel pump if it has one.
randy
03-30-2003 13:27:14
 Re: Re: trouble running in reply to JoeK, 03-30-2003 05:54:11
joe thanks,i thought i had clean the bowl, but evidently not good enough, i did it again and it rnuns good now,can"t get it perfect but fine for me, thanks again joe.
