Grease Pit
Slowpoke
03-28-2003 01:44:25
I'm thinking of putting a grease pit in my shop. Where can I get plans for installing one, either before or after the concrete floor is poured? Does anyone know if a permit is required? "Succesful Farming" had an issue of farm shops last fall and it showed two shops with the pits. Only dimensions for one pit were given: 3x5-1/2x20. The other pit was "4 feet wide"
Thanks for your input.
rayinny
03-30-2003 13:49:13
 Re: Grease Pit in reply to Slowpoke, 03-28-2003 01:44:25
Make sure you have a fast way out. if a flash fire occures it happens in an instant. I was in a pit and the car was started with the muffler off. It was just one quick flash but we ran out side in an instant Fires do occure in pits, gas leaking on drop light bulbs for example.
Scott Whiting
03-29-2003 16:13:04
I put a pit in my new garage when I built it and would not give it up for anything. To be able to stand up and change your oil or whatever is worth every penny I spent. When I got my building permit I told them I was going to do it and they put up a minor fuss. They finally let me with two rules, #1 no drains, they thought that I would just let my oil go I guess and #2 No electrical outlets or lights, because of fumes and sparks.
I made mine about 6 feet deep, you could adjust this depending on how tall you are. Sometimes I still need something to stand on but you don't want to have to duck all the time either.
What I did for the structure on it was to dig the hole and pour in a concrete floor then I laid up cinderblock walls. So the physical size of mine was determined by block layout. I think it is about 3' by 14' inside. Then I grouted the blocks full to give them strength and then backfilled the hole and poured the floor of the shop. I cant remember for sure how, but we tied the shop floor into the top row of blocks. You could use rebar or just leave the grout down a few inches and the floor cememt would run in and naturally tie the two together.
One more thing that we did was when we poured the shop floor we had to build cement forms on the inside of the pit so the cement didn't run into it. So on the outside of the form at the very top we attached some 2x2's. What this did was create a notch at the top of the pit wall in the shop floor. Then I cut some plywood sheets to lay in the notch when the pit is not in use. Keeps out the excess dirt and people don't fall in.
Sorry for the long post but if I was you I would go for it.
Gary in IL
03-28-2003 19:28:29
the injury liability issue alone (somebody falling in and breaking a leg or worse) makes me cringe..... ..let alone the potential for heavier-than-air fumes (gasoline for one) accumulating in the pit and being set off by a broken drop light
enough said..... ....
David - OR
03-28-2003 10:07:49
Grease pits for commercial facilities are heavily regulated in the building codes. There are special requirements for means of egress, ventilation, and electrical wiring.
Many hazardous fumes (gasoline vapor, propane) are heavier than air, and will settle to the bottom of the pit making it not the safest place to spend "quality time, especially considering the potential difficulty getting out.
Many states have "AG exemption" clauses from building codes. A lot depends on whether this is considered a place for maintaining farm machinery or whether it is a part of the "garage" appurtenant to your home. If you will have any employees or other paid workers in the pit, there are probably regulations that apply regardless.
For some ideas on how to build them, stroll past the nearest "Jiffy Lube" or similar emporium.
