Which/What HVLP paint system??
Dum Ole Bob
03-27-2003 07:10:37
I'm feed up with the over spray when painting with spray cans! Mostly using flat or satin black to paint steel items such as signs and coat racks, etc.
Any advice appreciated! Will hvlp give good results considering cost of the system? Is cleanup a messy thing? How long does it take to "set up" to paint? Is all that worth it to just paint a small item or two?
What systems are good? I'm not going to be painting restored vehicles, etc.
Thanks! Bob
DanPT2976
03-28-2003 05:15:04
 Re: Which/What HVLP paint system?? in reply to Dum Ole Bob, 03-27-2003 07:10:37
Hey Bob,
I used a friend's TIP sprayer (turbine type), WOW what a difference! I painted my Cat TEN last year, and used almost half of what I would normally have used with a "high pressure" gun. Almost no overspray. Another benefit I found is that the turbine blows warm air, which heats the paint slightly and lets it flow better. All that in mind, it's probably overkill for what you say you'll be doing, and expensive too (I think its about $600).
Good luck!
Dan
VaTom
03-28-2003 04:30:24
Hi Bob,
Your HVLP "systems" are two basic choices, an air compressor powered gun which will work with any compressor and a dedicated turbine powered gun. The turbine system is the several hundred dollar option that will give the least bounce-back with lower pressure. It's also independent of an air compressor, extremely portable.
I bought a turbine system sold by Tip, made at the time by Apollo, IIRC. A friend criticized me, telling me I'd never recover the cost through product savings. That wasn't the point. I wanted the best work environment I could get. It was worth the money- to me.
I spoke with Campbell Hausfield about their inexpensive turbine setup and they didn't think it was what I was looking for, furniture quality spraying. My wife's van also came out great.
Cleanup with any of these guns will be easy and require minimal solvent. There's a little relearning of spray technique if you're good with a normal air gun as I was. All guns, HVLP or not, have several adjustments that need to be made to get a proper spray pattern and product application. Your best bet there is to find somebody local who can show you. Not rocket science.
I leave solvent in my gun and my turbine sitting on a shelf where I normally spray. It'll take me maybe 2 minutes to get the right viscosity product in my gun and be spraying. It's really no big deal. I haven't bought a spray can in years.
This list has had many favorable comments on Harbor Freight guns if you're thinking lowest cost. I tried a gravity-feed (tank on top) once and didn't like it. Probably only because I was used to the other style. I also tend to spray enough to want over a pint of product in the gun. You said small parts so I gather you'd have no application for a paint pot, an option for larger volume users. Good luck with your decision, you're overdue!
Farmer/paul
03-28-2003 03:49:39
I have been using a Sata Jet (sp?) with good results, it has the cup on top (gravity feed) which takes a bit getting used to. Clean up of the gun is a bit easier than a siphon type gun.
Jeff
03-27-2003 13:13:21
I've got an HVLP gun from Harbor Freight.
For the 50$ it cost me, it throws paint pretty well.
Jim M (RI)
03-27-2003 13:55:22
 Re: Re: Which/What HVLP paint system?? in reply to Jeff, 03-27-2003 13:13:21
Autobody Store has a good site to ask questions regarding painting. I bought a DeVilbiss HVLP sprayer but haven't used it yet, but from everything I've read they are great. Hope this helps. Jim
