Metal saw selection
tjw
03-22-2003 15:49:54
Needing to cut 50mm X 50mm X 1.6mm square tubing and get a good square cut on the end.
What type metal saw - horizontal bandsaw, power hacksaw, or other would be the best (next to a cold saw, which is to pricey for me)?
I have a metal chop saw (abrasive wheel), but can not get a square cut. No matter how slow I cut!
I need the cut to be square for welding purposes.
Thanks.
Bernie
03-22-2003 17:47:06
 Re: metal saw selection in reply to tjw, 03-22-2003 15:49:54
You should be able to get square cuts with your ab saw. You might have to shim under the saw mounting brackets to get the blade 90* to the table. I did. Square the vise to the blade also. Another reason for non-square cuts is a bowl-shaped blade. Check it with a straightedge. HTH
Don LC
03-23-2003 20:25:33
 Re: Re: metal saw selection in reply to Bernie, 03-22-2003 17:47:06
Your cutoff saw will be close enough,the welder will make up the differance....get your self a couple of the megnetic angle,metal holders from Harbor Freight Co. they will hold the work, at 45* and 90*..... .you can also clamp the pieces, then tack them
Don LC
03-23-2003 20:25:20
