Reinstalling bolts in cylinder block on tractor
Randy
03-20-2003 12:31:39
I just had my cylinder rebored and they removed all the bolts that connect the head to the cylinder block when doing this. What is the best way to reinstall them? I've heard of a stud installer but wasn't really familiar with it. I just want to get them in there tight again without having to worry about any vibration working them out. Also, would I want to use thread lock or something else when putting these back into the block? Thanks for any information.
Randy
03-24-2003 08:40:54
 Re: Reinstalling bolts in cylinder block on tractor in reply to Randy, 03-20-2003 12:31:39
Thanks for all of the feedback men.
gatractorman
03-21-2003 02:33:32
On some engines the head studs screw into the water jacket of the block, if this is the case on your engine then some sealant is required to prevent leaks (not loctite), if not just clean threads, lightly oil and install, I use a stud putter-inner and taker-outter LOL.
Wayne
03-20-2003 22:29:18
We've always used a stud remover/installer, til the other day. Dad discovered something that's really the trick. If you can get one of the tall "connector nuts", like contractors use to tie threaded rod together, in the right size for your job, then your set. Simply thread a bolt about 1/2 the length of the nut in one end and thread the stud in the other, making sure the bolt and stud meet in the middle. All you have to do then is tighten on the bolt just like you would any other bolt, and the stud will screw right in. When your tight all you have to do is loosen the bolt and the bolt/nut assembly will screw right off. Dad put in 12 1/2 inch studs the other day in less than 5 minutes doing it this way. The good thing about this is all it takes is one wrench that fits the head of the bolt to tighten and loosen, vs two if you have to double nut them, and if your careful you can also put them in with an impact, and make things even faster, if you want. The only problem is it only works for installing them and not removing them, but that's what they make stud tools or double nutting for.
As far thread locker, personally I wouldn't do anything but oil them lightly. Being a stud, when you torque the nuts down on the heads, they aren't very likely to back out since. Usually the temps in and around the heads are high enough that any but the really good thread lockers aren't gonna hold very good anyway since most of them are designed to release with heat. Also if you do lock tite them in, and it does hold, and a few years down the road you need to do something that requires removing them, being where they are, it can be a real nightmare. This is my opinion based on experience, but, personally, if I wasn't 100% sure I'd still consult the mfg first since you can never tell what the engineer that designed it was thinking...I've seen some odd stuff out there recently...LOL Hope this helps. Wayne
Chris
03-20-2003 21:41:23
Double nut the stud,tighten the nuts together and thread them in as far as you can.That will work as well as a special tool on most studs. Thread locker is not neccessary but you can use it if you want. Don't go overboard . Just use the regular grade locker.(might want to get them out again some day!)When you torque the head down the stud will stay in just like they were before.
deadeye
03-20-2003 14:55:42
I have used E Z-Lok inserts.
Tom Keehan
03-21-2003 08:57:11
 Re: Re: Reinstalling bolts in cylinder block on tractor in reply to deadeye, 03-20-2003 14:55:42
If I were you I wouldn't use an impact wrench on the stud, If there is an oil or water in the hole you can blow a chuck of the block out. I have seen it happen and it's not pretty.
