Trailer tires
Dave
03-14-2003 18:02:48
Anybody know where 6.00-6.90x9 utility trailer tires can be obtained? Bought a small trailer and the tires aren't all that great.Everything local seems to be an inch bigger or smaller. No 9" tires to be found. Maybe I need to get different rims?
RWK in WI
03-22-2003 17:13:24
 Re: Trailer tires in reply to Dave, 03-14-2003 18:02:48
I had to wait until I could check my catalog but "Gemplers" in Bellvile, WI 1-800-382-8473 has High Speed Trailer Tires 6.90 x 9 tube type 1120 lbs. capicity C (6) rating Item # 3453 $39.50 Tubes Item # 1029.5 $10.90
I hope this helps you.
Dave
03-23-2003 15:04:42
 Re: Re: Trailer tires in reply to RWK in WI, 03-22-2003 17:13:24
Thank you for the info.!!
RayP(MI)
03-18-2003 08:49:01
Many trailer tires are sold on rims these days, often as cheaply as the local tire dealer can replace one on your rim. Check and see if you can find a mounted tire which will fit your bolt pattern.
paul
03-14-2003 18:48:25
check www.cedarrapidstire.com Cedar Rapids Tire Co. I have gotten mower tires there and always seem to have what I need in stock, other places always need to order, price is better too. can shop from the website.
paul
Kevin
03-14-2003 18:16:21
Gensco used aircraft tires has a 22x7.75Rx9 that cross indexes. I personally haven't tried aircraft tires, but I have read other peoples comments as being good tough tires cheap.
noflats dot com. HTH.
