Valve spring tester
Jerry L az
03-12-2003 09:54:03
anyone know where I can obtain one or make one thanks..... jer
John @ IL
03-13-2003 01:43:24
 Re: valve spring tester in reply to Jerry L az, 03-12-2003 09:54:03
Try Jegs
K-Mo
03-12-2003 20:50:53
I made one many years ago. As I recall, I mounted and 6" arm to a pivot point and welded an old 1/2" drive socket to it at the pivot point. I then used a bending beam torque wrench to measure the force. My pivot arm was 6" long so you had to multiple the reading by 2. I believe I also had a threaded stop that could be adjusted to the specified height.
Good Luck,
K-Mo
Jerry L az
03-12-2003 22:08:59
 Re: Re: valve spring tester in reply to K-Mo, 03-12-2003 20:50:53
Thanks for the ideas ..... .jer
DaveWis
03-12-2003 18:03:56
Speedway Motors in Lincoln, Neb. 402-323-3200 has one you use in a vise or drill press and also a stand alone one. They are good to deal with, we buy race car parts from them.
Jon Hagen
03-12-2003 12:37:22
A simple but fairly accurate valve spring tester can be nothing more than a bathroom scale(good quality electronic load cell type perfered) set on your drill press using the drill chuck to press on the valve spring retainer. Should have atleast a 6X6 metal or wood plate between the spring and scale to distribute the load on the scale platform.
