Air Compresor Search
Kevin
03-11-2003 11:52:04
I have been looking at two stage air compressors and have narrowed my search down to a choice between: Ingersoll-Rand and CastAir. I am looking at the Ingersoll-Rand models, TS5N5-1 and 2475N7.5, CastAir C1 5 hp unit. Any information or comments on the units would be appreciated.
KURT
03-14-2003 08:47:54
 Re: Air Compresor Search in reply to Kevin, 03-11-2003 11:52:04
Ingersoll rand makes a very good piston type compressor. I have also heard good things about the Campbell hausfeld compressors too.
Slowpoke
03-11-2003 21:58:46
I have an IR 2475n7.5 made in 2000 purchased used for $700 in Sept 2002. The machine shop went out of business. It's in storage waiting to be put in a new shop building. You need 27 amps @ 230v to run it. It's two stage, 175psi, 24 cfm with a 7.5 hp motor. Probably more than enough for a home shop, and it should be ok for reasonable sand blast duty. No mater what you get, put in an automatic drain.
Dave Wis.
03-11-2003 16:26:30
I have a 5hp Castair compressor. I am very happy with it. I have the automatic drain on it which works great.
