Pole barn teardown
pat woodruff
03-05-2003 19:12:33
I was just given a pole barn. I have to have it off the site by this weekend or it is going to be bulldozed under. What is the best way to take this thing down? I have electricty at the site so I figured a sawsall might work in cutting the nails. Any tips would be appreciated.
thanks.
Pat
old bones
03-09-2003 16:00:08
 Re: pole barn teardown in reply to pat woodruff, 03-05-2003 19:12:33
probably too late, but see my post up above about a steel removing tool. really works well.
Chris L
03-07-2003 17:37:50
To get nails out of metal siding I have successfully used two hammers - one to pound the other's claws beneath the nail - it works quite well - but was very time consuming.....
KX
03-07-2003 12:49:07
Take some good help. Take the frame down from the top down and be careful. I know this sounds cliche, maybe even corny but I have a neighbor that tore down an old barn. He thought he would save as much lumber as possible and he pulled one of the last rafters loose while the walls were still standing thinking he could just step outside as it fell. He was wrong. He only made it because a passerby saw it happen and rushed up to find a tall boy jack and lift it off of him. He said he could feel the life being squeezed out of him and he thought that was his last day. This is a guy who is a carpenter all his life, knows building and is a very successful farmer. One second of poor judgement isn't worth what it could cost. Take your time and be careful. Good luck.
Bernie
03-06-2003 06:44:14
Use a small angle grinder and grind the nail heads off. If there are rubber washers under the heads you won't touch the metal. If they are aluminum nails you can cut/twist them off with a pair of hoof trimer nippers. I've done both.
Errin OH
03-06-2003 06:10:35
Your on the right track. I've pulled down several and the sawsall is the handiest tool you'll have on site. A flat 18" pry bar, and big hammer is just about the only other tools needed.
You didn't say but if metal siding nailed on, get one of those "cats claws". Its a short (6-8") nail puller bent 90 deg on the end. Start the nails by lightly hammering the claw, on then pull with hammer. Don't pry on the nails, it will only distoret the metal.
If its a T&G wood siding use the flat prybar to seperate it from the stringers and cut nails. I did one like this and found it was best to go the whole lenght of the wall on the base, stringers and top rail, then go back and cut them loose, base, stringers, top and let my helper grabe them as the last nail was cut on the top run. Saved 90+ percent. Pounding on them will do noithin but break the T&G part.
Another tip, work from the top down. The first one we did we took all the siding off first and that made for one wobbly job up top. Next (and every other) we took the roof off, droped the trusses, then the walls. Much, much eaiser.
If you plan to save post, you'll need a rig capible of pullin them. We used a case teratrack loader. If there set in concret, plan on doin some digin.
PS - your goin need a bunch of blades for that sawsall if they used harden nails, which, I bet they did.
Hayman
03-07-2003 19:37:55
 Re: Re: pole barn teardown in reply to Errin OH, 03-06-2003 06:10:35
If you are in a fairly remote area you can let of some dynamite inside the building,just enough will loosen all nails and make dimantling quite easy.
