What kind of press for sharp bend in 10 guage steel
DumOleBob
03-04-2003 21:07:10
I need to make sharp right angle bends in 10 gauge mild steel up to 8� to 10� wide. Should I be looking for a press? A hydraulic press? A air over hydraulic? A "brake"?
Are the shop presses with removable auto jacks too slow? I don�t need a production type outfit, but I don�t want to pump, and pump, and pump for little or nothing. What should I look for & what options are worth considering?
Where do you get "tooling"?
Gad - I am Dum Ole Bob!!!
john
03-05-2003 03:57:27
 Re: What kind of press for sharp bend in 10 guage steel in reply to DumOleBob, 03-04-2003 21:07:10
Bob,
here's what I built with a 20 ton jack... I'm going air over hydraulic a.s.a.p. lots of pumping..but I don't use it every day... this press will put a nice 90 in 1/4" x 3" with very little sweat.. I've got plans if your interested
Link
hope it helps
john
ps..its a knock off on www.shopoutfitters.com unit
T_Bone
03-04-2003 23:57:27
Hi Bob,
Your talking alot of hydraulic power, 40tons to do 10ga. The bottom die would be 1" with using a knife top die. Using a 90* top die will not yeild a finished 90* bend in 10ga on a close radius and thats why the knife die is needed. You can find used dies at any machinery sales shop, grab both cheeks as there expensive.
To make one is going to be expensive and to use a piece of equipment not designed to brake metal your final product will be soso. Cost effective? Depends on what the job requires and the quality of product wanted. If just a few pieces, 100 or so, then it will probably be more cost effective to shop the work out.
Now if your looking at a home shop press brake idea, then man do I have some suggestions as I'm building a hydraulic 4 footer. A roundtoit project on the back (very low) burner.
T_Bone
