Lincoln AC-225 welder
Roy Warbis
03-02-2003 17:22:37
I currently own a small (120V) wire feed welder & would like to try a Lincoln AC-225. The wire feed is the only thing I've ever welded with. Question: Is it tough learning to stick weld & how deep will the AC-225 "dig"? Thanks for any help.
Gustavo Gonzalez
09-15-2003 13:46:38
 Re: Lincoln AC-225 welder in reply to Roy Warbis, 03-02-2003 17:22:37
I need the electrical diagram for a lincoln ac 250 1980, thanks
Roy Warbis
03-04-2003 15:49:22
Thanks to all of you for return info on this welder. I'm buying one tomorrow!
T_Bone
03-03-2003 18:53:56
Hi Roy,
Nothing wrong with the Lincoln AC buzz box as I've had one for 20yrs but,
Take alook at the Miller Thunderbolt XL. I just bought my son one last month. AC/DC(150/amps) with a "infinite" amperage control, not like the switched 15amp steps on the Lincoln. Machine street priced at $410. nice machine and well worth the cost for a buzzer.
Do a search on electrodes as there's been alot of good info posted this past year with 6010 being the best penetration rod.
T_Bone
SHeiserman
03-03-2003 19:03:39
 Re: Re: Lincoln AC-225 welder in reply to T_Bone, 03-03-2003 18:53:56
T-Bone- Can you tell me why you can't buy 6010 from a farm store. 5P is what we use at work,but the only place I've ever seen it is at weld supply, and the nearest one of those is 45 miles away. 6011 works well for me as the next best thing.
T_Bone
03-03-2003 19:13:48
 Re: Re: Re: Lincoln AC-225 welder in reply to SHeiserman, 03-03-2003 19:03:39
Hi SHeiserman,
A farm store only carrys the most popular rods there clients use or they think they use. A welding shop carrys a much larger selection as thats there bread and butter. A welding supply will typicaly beats out a Farm store prices by alot, hence why it's best to buy at a welding supply.
6011 works very well on AC or DCEN but if I have a DC machine then theres nothing thats beats Lincolns 5P/(6010)
T_Bone
SHeiserman
03-03-2003 19:23:25
 Re: Re: Re: Re: Lincoln AC-225 welder in reply to T_Bone, 03-03-2003 19:13:48
Right on. Do you prefer Atom Arc or Code Arc 7018? I like the Atom Arc, for looks of course.
T_Bone
03-03-2003 19:44:25
 Re: Re: Re: Re: Re: Lincoln AC-225 welder in reply to SHeiserman, 03-03-2003 19:23:25
I've never heard of Code Arc??? and I haven't seen Atom Arc? in years, and that name don't sound right but don't remember it with 7018, maybe a off shoot for another electrode I used?
Chemtron 7018 is the finest 7018 ever produced :)
T_Bone
SHeiserman
03-03-2003 20:29:17
 Re: Re: Re: Re: Re: Re: Lincoln AC-225 welder in reply to T_Bone, 03-03-2003 19:44:25
I'm almost positive they are both Lincoln rod. We have to use Code Arc on R stamp work, don't know why however. I know it has to come in a sealed can. I'll see if I can find Chemtron.
Matthew
03-03-2003 15:36:01
SHeiserman or whatever hit the NAIL on the HEAD. Learning to weld is not all that hard. The hard part is getting a good bead formation in all positions. I would strongly recommend the 6013 for a beginner. I'll be honest with you. I have never welded with a 6011 and as a matter o fact don't plan on it. The 6013 will make you feel good because it turns out real well when it comes to appearence. I will have to agree on one thing though, the 7018 is also a rod with an excellent appearence. However, as a beginner, you will want to try and find the 7018 that is made for AC welding machines. Arc restarts are effortless as with the 6013. The normal 7018 work best on DC but if they are all you can find then here is a little tip that will work fo any rod. After you break the arc and want to restart it take your finger tips and break off the extra slag at the bottom of the rod. With most rods this is not necessary,but can be helpful sometimes. Just my $0.02. Good luck and Happy Welding.
KX
03-03-2003 08:29:41
If you can wire weld you can stick weld. I would advise though to keep your wire welder as well. Use the stick for heavy iron where you need good penetration/fusion. Good luck to you.
Don LC
03-03-2003 07:52:08
I have a Lincoln AC 225 that I bought I bought new at Tractor Supply back 30 years ago (1973),it has copper windings,I bought it on sale for $94....the only thing I have done to it is put 25 foot, heaver cables on it and a better rod holder.....no problems.....If I was buying one today, I would look for a used one,with copper windings....they started using alumumm about 20 years ago....you might contact their service dept. and ask them when they changed over.....I use mostly 6013 rod,hold your arc so it sounds like bacon frying....If you can wire weld ,you can stick, weld..... good luck.
Don LC
03-03-2003 08:00:34
 Re: Re: Lincoln AC-225 welder in reply to Don LC, 03-03-2003 07:52:08
Secret for long welder life = Turn it on let it warm up, 2min.----On shut down let it run about 3-4 min. before turning the switsh off.
Al
03-02-2003 19:47:47
I have been welding with my Miller 225 AC for about 3 months. Safety at first is a big factor as this makes you feel comforatable. One of the best welders in our area keeps a very steady hand. If I'm standing and welding I use a prop to keep from weaving - a kind of third leg triangle. At first starting the arc and getting a good looking weld required a lot of practice. 6011 is a good rod to have in your collection for penetration. Seems to be twice good as the rest I've tried. I'm still a leaner , but I enjoy it. Best advice I can give "is find a friendly welder for a quick demonstration". Good luck.
SHeiserman
03-02-2003 18:09:12
It's not tough learning how to weld. The hard part is making it look good. I feel 7018 looks best, but metal needs to be nice and clean. 6011 would be my choice for penetration, and cleanliness isn't so important. I'd think you'll be happy with the stick welder, they are awful handy. Just takes practice.
