Oxy/acetylene vs. electric welders
Bandit
02-28-2003 12:00:33
What would some of you experienced folk reccomend. It would be for a farm shop I know most have electric welders, but I'm thinking of the portability of a gas welder. Some field repairs might need done wich rules out the electric. But would have to buy gas where as electric only rods would be needed. Anyway, what do some of you think?
JohnnyB
03-01-2003 16:35:35
 Re: Oxy/acetylene vs. electric welders in reply to Bandit, 02-28-2003 12:00:33
You can buy a decent used cracker box welder for under $100. I'd be lost without mine. I'd also be lost without my torch, don't do much welding with it, lots of cutting. You really need both for a basic shop.
Central Minnesota
03-01-2003 08:42:54
For a single versatile welder I think the Oxy/Acet is probably the best way to start. It's low budget. You can weld, braze, solder, silver solder, body lead etc. With practice you can do aluminum (using the correct rod) It's not good on light sheet metal since the general flame is too wide so that it tends to buckle the large flat areas. You can use it to cut steel and cast. You can heat with it if you want to do some small blacksmith work.
OK, you posted this on antique tractors. Does that mean you're a collector. If you are, I have an elderly (1950's) General Electric 200 amp DC welder on a trailer. It's powered by a 4 cyl watercooled Hercules engine. Runs alright but doesn't look real pretty. I've used it on boilers, structural steel, and heavy castings, as well as light stainless with a Tig torch. I'd sell it for $495.00. If you're interested you can email me. Central Minnesota
Wayne
02-28-2003 21:17:09
Personally I'd keep an eye on E-bay, etc and find something like a gasoline driven Miller or Lincoln welder. My choice is the Miller, but both manufacture good machines. Depending on the model you chose they can be used for just about any type of welding. Hook up the cables and your ready to stick...AC/DC, straight or reverse... Set the controls, hook up a feeder, and your ready to MIG...and the same goes for TIG, set the controls, hook up the torch, etc and it's ready to go. The nice thing is if you put it on a trailer, or have a way to put it in the bak of a truck, it's totally portable. Price wise you can get a used engine drive for less than $2000 if you take some time to look. If you buy a straight Stick, MIG, or TIG power supply/welder, your limited as to it's uses, but if you buy a multiprocess power supply/welder, be it engine drive or electric, you can always add on as your needs, skills, etc progress. Another plus is that most also include a generator of at least 4000 watts, and the newer ones go as high as 10,000-12,000 watts...always a plus when the power goes down.
Just my .02.....Wayne
T_Bone
02-28-2003 19:24:52
Hi Bandit,
A oxy/acet torch is a must have as it can be used in so many different applications from cutting to welding.
For another $410 you can get a AC/DC Miller Thunderbolt, 150A/DC, 225A/AC. I really think that most field break downs can be "limped" back to the shop for a weld repair, if not rent a 5kw generator for those rare occasions a field weld needs to be done.
Both can be had for about $1000 including gas cylinders and assc. That will do 99.9% of the home/farm/lite commerical jobs that need done. Only if you were in the business would it pay for more expensive equipment. It's like me messing around growing crops on my 3 acres comparred to the guy that farms 1000acres. I can get by with a small 20hp tractor where a 1000a needs some serious HP.
Do a search on this forum as there's alot of great info posted here.
T_Bone
Ray,IN
02-28-2003 19:13:59
I've got both, an oxy/acet outfit, and a Lincwelder 225 DC gas powered welder with 120VAC output also; I use this almost exclusively. I load it into the truck or a trailer behind a tractor to take it to the work when necessary, and I've got 120VAC for lighting, power tools, spray guns etc. whenever needed. I probably use the gas outfit only 4-6 times yearly but will not dispose of it because when I need it nothing else will do.
Joe
02-28-2003 16:03:41
well this is one of the hardest questions I have thought about in a long time because over the years I have purchased a oxy/act torch that I use almost every day a 110 mig, a 220 mig, a ac/dc stick and a plasma cutter and for the life of me I can't say that i could give up any of them it all depends what you are going to do with them if you need portability I would tell you to start off with gas and than set up a battery stick welder with two deep cycle marine battery's and a set of 25 to 50 foot welding cables so you could cut and weld
Richard Fazio
03-01-2003 06:20:59
 Re: Re: Oxy/acetylene vs. electric welders in reply to Joe, 02-28-2003 16:03:41
Joe, are you using batteries to weld? Are you using a ready welder or just cables to a set of batteries? I'd like to do the same. I already have the batteries setup. I'm just a little leary on how to do it properly.
mj
02-28-2003 14:23:11
I used to use my torch for most any work thinner than about 3/32 and stick for anything thicker. An exception of course was seam work on sheet metal such as wagon boxes where 1/16 rod and DC reverse polarity (electrode +) is the ticket. 8 or 9 years ago I decided to get another MIG and decided that I didn't really need one with more capacity than 1/8 to 1/8" material so I bought a Lincoln 110v machine. With the gas shielding it's great for touchy stuff like moly steel motorcyle frames, etc. With flux-core wire it will join heavier materials than with the gas (due to the cooling effect of the gas flow) and makes a good unit for light portable use when coupled with my 5K generator. The MIG now does 90% of the jobs that the oxy-acetylene used to do. BUT I still use the torch for cutting, heating, brazing and some cast iron work. If I was 'starting new' and doing mostly general shop work (no structures) I'd get a 220v input MIG and a torch. The bigger MIG would pretty much take care of the jobs my stick does now. That's my set-up and I'm stickin' to it..... .unless I hit the lotto!
F14
02-28-2003 12:57:36
I don't see how anybody that does much welding/metalwork/fabrication can get along without one of each.
I've got a MIG welder instead of a stick, but one day I'm gonna find the right deal and have a stick welder too. Big trick is to sneak it into the shop without the wife seeing it...
Chester
02-28-2003 12:13:24
Have had both for many years, and use gas for thinner work, mufflers and bodywork etc. Use electric for welding heavier things like angles, flats, pipes etc. Only work in my garage shop so mobility is not an issue here.
Chester
