What size Gear Puller is needed
Jess
02-28-2003 07:50:33
I presently have two gear pullers. The larger one has a 9 inch spread. I am interesting in buying a bigger puller to do service work on on a JD 60 and a JD A. I would like to get by with buying only one more puller. I am looking at two pullers from NAPA--one with a 12 inch spread and one with a 15 inch spread. Can someone tell me if the 12 inch spread puller is big enough for anything I might run into on two cylinder JDs or do I need to go to the 15 inch puller. Also if you know of a vendor other than NAPA that I should check out please advise. Thanks for any info
tortmort
02-28-2003 20:15:14
 Re: What size Gear Puller is needed in reply to Jess, 02-28-2003 07:50:33
I do not have the answer but I would suggest you call one or two or three JD dealers and ask to speak to service/repair Department. They would know.
