Air pump for sandblasting
john r
02-22-2003 21:37:28
I have a old positive displacement air pump off a old grain vac. Will it run a sand blaster? any hints or ideas? thanks
Bill Smith
02-27-2003 21:34:00
 Re: air pump for sandblasting in reply to john r, 02-22-2003 21:37:28
Not positive what kind of a pump you got or how it would work. But I do know that when you are painting or sandblasting and using constant air, you are going to want something that will supply a constant pressure. Ussually on typical air compressors you would want a fairly good sized holding tank to keep things going. The tank provides volume, and since most pumps aren't able to put out a high constant pressure, the volume is needed to give you a constant air pressure. I thought grain vac pumps created a vacume and not air pressure. If it could be reversed or something to pump air pressure it would depend on how many constant PSI's it would be capable of putting out. Not saying it isn't possible to rig something up, but I would almost say you would be better off doing something different.
