How many ohms resistance in a 3-position light switch ???
Alberta Mike
02-22-2003 16:12:49
In the old-style 3-position light switch that many tractors had (40's and early 50's), there is a small resistor (wound around a mica plate) wired into the "full-in position" that controls generator output for a 3rd brush generator system. I'm trying to measure how many ohms of resistance the original resistor had. So far (with the pieces of wire that are left here that I have) I measure about 3 ohms. Is that close to what the original switches had?
mj
02-22-2003 16:33:58
 Re: How many ohms resistance in a 3-position light switch ??? in reply to Alberta Mike, 02-22-2003 16:12:49
I have an original J.I. Case VA Series Service Manual (Rac258) and it does not specify the resistance for the light switch resistor. An ohm-meter was probably not as common when this book was written (1948?) as they are now.
mj
02-23-2003 13:28:39
 Re: Re: How many ohms resistance in a 3-position light switch ??? in reply to mj, 02-22-2003 16:33:58
I checked 2 Case VAC 3-position light switches this morning and got 2.9/3.0 ohms.
