Mig welder
linx
02-22-2003 06:31:29
can I use any rubber hose to connect between the mig welder and the regulator; or is it a special typ of hose ?
T_Bone
02-22-2003 16:48:12
 Re: mig welder in reply to linx, 02-22-2003 06:31:29
Hi linx,
I've used both rubber and poly and didn't have a problem. I like the rubber the best and a 25ft if your dragging the head around away from the cylinder.
If the cylinder is on the machine then just long enough to make the connections.
T_Bone
Scott V
02-23-2003 23:51:32
 Re: Re: mig welder in reply to T_Bone, 02-22-2003 16:48:12
Sometimes a little extra on the machine is handy if another machine has a different gas.I am always robbing straight argon from my tig to my wirefeed for pulse aluminum welding.Keeps me from buying,and moving another bottle.Or just swapping 75/25 from one mig to another using 90/10 gas.So a little extra is ok,atleast for me it is.
Scott V
02-22-2003 12:27:27
Jerry is right,I bought 20 feet for $15.00 yesterday,and they put the right ends on it.
Jerry
02-22-2003 08:24:20
It would probably work for awhile but I wouldnt advise it. Just go to your local welding supply and have them make up a proper hose for you. You will be surpised how little it costs.
