Gene Davis
02-23-2003 20:09:36
Re: Chevy Suburban in reply to Andy, 02-22-2003 05:33:04
Have had 2,a 91 GMC Suburban, it was ok, sold it and bought the 93 we have now that a doctor bought new, he changes vehicles at 100k miles he said, and he went 20k over this time because he had just had a mr goodwrench auto/overdrive trans installed in it. It is not a vortec, so it only gets about 15mpg. loaded or unloaded it is loaded with most options except 4x4, and I don't want that one. We use it mostly for traveling and it has the front & rear air, the tailgate w/wiper and I prefer that to the barn doors in the rear, it eliminates the blind spot from the middle door post on barn doors. It finally put me down last week at 189k miles, the fuel pump quit, was not too bad a job to replace other than getting the fuel tank emptied of gas (42 gal tank), like the fact that with a large tank I can pick the place I want to fill up. It is very comfortable to drive and ride and the towing rate is about equal to a pickup of the same 1500, or 2500 series. It needs a towing package if you do much heavy towing and adding an extra trans cooler is good insurance, they last longer when the fluid stays cool. I have the local trans. shop flush mine, about every 30k miles on their machine rather than just drop the pan and change filter and 3 or 4 qts of oil. also don't do any heavy towing in overdrive, use regular drive to make the trans. last longer and also the engine helps with the braking. The Vortec 5.7 engines,(have 2 of them,97 gmc pu & 97 tahoe) seem to be bad about the intake manifold/water jacket gaskets giving way about 100-120k miles, this is a booger to replace! Other than that they have been good engines. They consistently yield about 17 mpg. Am intending to drive the 93 suburban 250-300k miles. Will be driving it to Ft.Walton Beach, Fla. and to Atlanta Ga, next month, then to Wilmington,N.C. the next month. SLE and SLT are different levels of trim think the SLT is the higher level with maybe leather seats. I have the SLE and like it because the cloth seat are not as hot in the summer, and not as cold in the winter. Have to reccomend the Suburban Very highly in my own case. Gene Davis Tennille, Ga.
