Hello All: Tricky Question, the answer is that it depends. Based upon my Mark's Standard Handbook for Mechanical Engineers .... For 3/4" steel pipe with a working stress of 12,000 psi (i.e., max working stress for ASTM A120 pipe) Schedule 40, 0.113" wt, 2,582 psi Schedule 80, 0.154" wt, 3,520 psi Schedule 160, 0.218" wt, 4,982 psi Schedule Numbers are per ANSI B36.10. The main concern will be with the fittings that you use with the pipe. Most fittings available from hardware stores and building supply stores are for nonshock service (i.e., hot and cold water plumbing) at temperatures below 300F. They are at best capable of withstanding a pressure of 150 psi. For use with an airline system, I would recommend purchasing what are known as 300lb fittings. These are rated for use at 300 psi with saturated steam. They can withstand a higher pressure in cold use (i.e., less than 300F). Also available are 150lb fittings. They are available from plumbing supply dealers. For a hydraulic system, you will need to know what the relief valve setting is on the system. Steel fittings are available with pressure ratings up to 6000 psi. You can order these fittings by referring to the pressure rating; i.e., 1500lb, 3000lb, 6000lb, etc. Hope this helps.
