Pressure switch
chris smith
02-14-2003 14:39:03
I need to reset my pressure settings on my air compressor. I am not changing them just putting them back to spec. It has two bolts with a spring washer and nut on each. There are located one on one side then one on the other side.. Could you please tell me how to adjust this style???
Thanks so much..
George G
02-15-2003 10:14:57
 Re: pressure switch in reply to chris smith, 02-14-2003 14:39:03
One adjustment would be the max psi setting. The other would be the pressure differential setting. To find out which one is which. I would run the compresser up til it shuts off. Record the psi that it shut off at. Slowly drain psi off til it restarts. Record the psi that it restarts at.Once it gets back up to psi. Shut the power off (electric).Then facing the front of the switch, I would backoff the adjustment on the right about two turns counterclock wise. Drain the psi down about 50 psi, turn power back on. If the compresser shuts off at a lower psi than before. Then you backed out the max psi adjuster. If it shuts off at the same psi. Slowly drain psi down, it should restart at a higher psi than before. At this point you should know which adjustment is which. The psi differential should be set to restart the compresser at 10-15 psi less than max.
Gary
02-14-2003 18:37:32
Remove the cover from the pressure switch. Youy will see one of them moving more than the other as youbleed air off. You will see the other moving the most and then, finally, jumping as it reaches its cutoff pressure. Tichten down for more pressure, back off for less. If it is one of these foreign made, high speed jobs, don't set it to factory specs. Set it for less. I've change a bunch of gaskets due to them blowing between the primary and secondary cylinders.
