How to remove sand
Gary
02-13-2003 14:14:46
Maybe, just maybe, someone here will have an idea for me. I would like to remove sand from my crawlspace. The only access I have is through small casement windows. Is there some kind of pump that would pump dry sand?
Gordon in IN
02-15-2003 19:56:19
 Re: How to remove sand in reply to Gary, 02-13-2003 14:14:46
A large powerful shop vac. modified to fit on a 55 gallon metal drum. Use two drums, fill about half to 2/3 full. With two men, one working the "hose" and one emptying one drum while the other drum is being filled, a lot of DRY sand can be moved in a short time. Have even used shop vac's to clean (dry) dirt and gravel out of ditches. Good luck, Gordon
charlie
02-13-2003 16:20:50
how much sand are you wanting to remove.if it's a large amount check into a vac truck.they can be costly but a fast way to get it done.good luck
John in MA
02-13-2003 14:24:07
Cheap shop vac with a good filter?
RayP(MI)
02-13-2003 18:13:44
 Re: Re: How to remove sand in reply to John in MA, 02-13-2003 14:24:07
Done it that way (shop vac) slow, but it works.
Could you use a grain auger?
Gary The Rookie Farmer
02-16-2003 09:08:01
 Re: Re: Re: How to remove sand in reply to RayP(MI), 02-13-2003 18:13:44
The grain auger is a good idea but I suppose I would have to buy one, I don't think anyone would like the idea of loaning an auger and have someone run sand through it.
kam
02-16-2003 16:53:20
 Re: Re: Re: Re: How to remove sand in reply to Gary The Rookie Farmer, 02-16-2003 09:08:01
The grain auger works, I've moved over 20 cu. yds.
of dirt twice. Be aware that it is slow, much slower than a belt. A screen is required to keep rocks/branches/
roots/etc. out.Sand will wear the auger out ,so
buy a used one, and calculate the cost of the auger in your job. A rented belt requires you to
do your digging in one or two days, but if you own
an auger, I was able to spread it out over a 2 week period and still get a few hours of use
over a period of years.
