Timing a 6v pos ground tractor
Scott
02-10-2003 14:31:04
I'm needing to check the timing on our tractor. How do I do this? I've timed many 12v neg systems, but don't know if the 6v pos can be done the same way. Can I use my timing light? When hooking it up, do I hook it to the pos or Neg?
Thanks for any help.
Richard Fazio
02-10-2003 15:20:35
 Re: Timing a 6v pos ground tractor in reply to Scott, 02-10-2003 14:31:04
The easiest way is to connect the timing light to a 12 volt battery the normal way, and onto the tractors spark plug. I use a 12 volt battery on the floor boards. You could also park your car next to the tractor and use it's battery if the leads are long enough.
deadeye
02-10-2003 15:18:46
Your timing light may only be a 12v. light. Should say on it somewhere. It will also depend on how old the light may be. You can work around that though. Just hook the light up to a 12v battery setting close by and the electrode wire to the tractor. My 12v light works for me on 6v. systems this way.-----deadeye
Richard Fazio
02-10-2003 15:21:27
 Re: Re: Timing a 6v pos ground tractor in reply to deadeye, 02-10-2003 15:18:46
Funny we both posted at the same time.
deadeye
02-12-2003 04:51:11
 Re: Re: Re: Timing a 6v pos ground tractor in reply to Richard Fazio, 02-10-2003 15:21:27
Great minds run in the same channels !!!!! ! ---deadeye
