What oil do you use in your air tools??
Chris Smith
02-10-2003 14:00:42
I have always used oil labeled as air tool oil. But i have read that you can use other types of oil.. What do you use?? And also, what is the ideal rpm for a compressor pump to run?? I always heard about 8-900 rpms??
Thanks again Chris Smith
dave
02-15-2003 09:15:14
 Re: what oil do you use in your air tools?? in reply to Chris Smith, 02-10-2003 14:00:42
I have been told never to use a detergent oil as it can break down your O- Rings, I usualy use the lighest weight I can find. We use nail guns etc all day long and never had any problems. I one time had a guy working for me dump 10-30 in a few of the nailers by mistake, 3 guns took the O- Rings out in a week or so- 2 others it did not effect at all. I figure down time and the little cost factor we usualy attempt to use the specified oil when ever possible.
Don LC
02-17-2003 03:56:46
 Re: Re: what oil do you use in your air tools?? in reply to dave, 02-15-2003 09:15:14
Use oil for air tools ----I have a qt. can that must be 15 yrs old..... I am in my "Play" shop 3-4 days a wk..... .do not use auto trans.or hyd. oil..... .
dave
02-15-2003 09:14:58
MPK
02-12-2003 18:46:24
I use ATF oil. My son-in-law is a mechanic and he says in the shop that's what they use.It's cheaper and a very good lubricant and good cleaner also.
Village Blacksmith
02-10-2003 23:49:24
I like Marvel Mystery Oil mixed with about 1/3 kerosene. It flows quicker and cleans better.
TAB
02-10-2003 19:08:58
Marvel Mystery Oil here.
Paw Paw Dave
02-10-2003 16:37:12
I've used ATF (not real particular of which one) for almost 30 years with good results. Some people prefer Marvel Mystery Oil. Dave
Chester Glenn
02-10-2003 15:07:05
"air tool oil" is just 10 weight light duty oil, any light oil of that viscosity would be ok. I have even used a hefty dose of wd-40 in a pinch but would not reccomend it on a regular basis as its lubricating properties are not long lived.
