Aluminum wheel damage vs. temperature
BillWV
02-08-2003 10:07:50
YTers,
I'm hoping some of the welders out there can give me an informed opinion. A friend of mine has a Dodge pick-up with aluminum wheels. It was in the shop Friday, and as he was driving it home, one of the front brakes was dragging. He didn't know it until halfway home on a 30 mile trip. He noticed it was driving "funny", and when he got out to see if he was getting a flat, etc, noticed the brake rotor was hot. Glowing orange hot. Now he wonders if that much heat would damage his wheel. I know that aluminum loses strength rapidly with heat, but don't really know any specifics. We're wondering if the wheel should be replaced.
Thanks,
Bill
T_Bone
02-09-2003 10:08:15
 Re: Aluminum wheel damage vs. temperature in reply to BillWV, 02-08-2003 10:07:50
Hi Bill,
AL does not show heat patterns like steel does. Most wheels have a protective coating on them and that would show how much heat was applied to the wheel. I don't think it will be enough to cause problems as there is a air gap around the heat source and that should be enough to insulate the wheel from heat damage, just like roof thimbles help wood stove pipe. In this case AL would do alot better than steel as AL would dispitate the heat faster than steel.
I would look at it twice tho, just to make sure you don't miss some heat damage on other parts.
T_Bone
Frank M.
02-08-2003 18:56:05
I don't know about the wheel but I WOULD replace the tire. That much heat has damaged the bead of the tire. I saw that on a truck tire back in the 70's Almost got a tireman killed when the bead blew.
rhouston
02-10-2003 13:25:55
 Re: Re: Aluminum wheel damage vs. temperature in reply to Frank M., 02-08-2003 18:56:05
if Its a 4x4 I would also replace the wheel bearing. $229 at dealer. I've got a good trick to remove it if you need to. last dealer I was at beat it out,AND charged me the time, there is an easier much faster way.
John Ne.
02-08-2003 16:12:38
Having had to cut off locking lug nuts on aluminum wheels, I think the heat dissipation of aluminum is pretty good, is the wheel discolored? Do the lugs tighten pretty well? Is the tire scorched or damaged? I think it got pretty warm, but haven't seen heat damage to a wheel from this yet. John in Ne.
