Welding goggles elastic woes....
Jerry A.
02-05-2003 15:29:56
Am I the only one that hates the elastic on my cutting torch goggles?
I've had a few different goggles for use with the acetylene outfit, but the darn elastic seems to stretch out permanently in just a few weeks or months, making the things worthless to stay on right.
Any suggestions for a different product or a good replacement for the cheap elastic provided with these goggles?
wapenn
02-06-2003 22:52:49
 Re: Welding goggles elastic woes.... in reply to Jerry A., 02-05-2003 15:29:56
Bicycle rims have a narrow rubber strip which goes around the perimeter of the rim between the spoke ends and the tube to protect the tube. These are about a half inch wide, stretchable, and you could probably get several stretchies from one. If they are not strong enough single, you could double them up. You should be able to find them at any bike repair shop, maybe even WalMart or the hardware store, or if you have a junk bike rim around which is not in use, have at 'er.
Bob
02-06-2003 08:33:43
I've just been using the elastic from worn-out underwear. It lasts OK, the wide band is a lot more comfortable, and you can't beat the price. My waist is twice as big as my head, so I get two bands from every pair I "ruin".....
Jerry
02-06-2003 07:04:45
Are you stuck on havng googles? Like Matthew I like to use the shade 5 safty glasses. Much less hassle and the little lenses are replaceable
cannonball
02-06-2003 06:19:19
i have had same problems, i buy surgerical rubber from a medical supply and use that..the last time i had to get bigger that needed and i split it in half and had two straps..have seen this last 5 years or longer, depends if left in sun..have nice day
Larry
02-06-2003 04:13:34
The main thing is not to hang the googles by the elastic, yet that is usually where their found,hanging on the regulator handle or on a hook on the cart.
Ol Chief
02-06-2003 04:04:31
I have the same complaint and problem.In the 1960 thru 1970s area,welding supply companies sold solid rubber bands for the goggles.Ihave not seen thosein years.Ihave been wanting to go to a rubber miller supply house and ask to have them cut some strips. Glad you brought this up. I will find time for this soon and advise you if Iam successful.There has to be a solution to this everlasting problem.
ShepFL
02-05-2003 19:59:13
I took the rubber out of my kid's snorkle mask. He broke the lens and I robbed the rubber pieces, it is adjustable and holds googles firmly. Has been working good for last 2 yrs. Good thing though I live so far back in the woods, no one from I-10 can see me in my get up. ;)
Ray M41
02-05-2003 17:35:45
I cut a strip from discarded inner tube. If the tube is fairly new the strip last a long time.
T_Bone
02-05-2003 16:15:01
Hi Jerry,
I like using #4 3/4 face shields. Works well and you don't have to worry about fitting over eye glass. There about $15 for the lens plus head gear if you don't have one.
T_Bone
Matthew
02-05-2003 18:02:13
 Re: Re: Welding goggles elastic woes.... in reply to T_Bone, 02-05-2003 16:15:01
I like to use the safety glasses that are shaded to a #5 shade. I buy them at HOLOX. Just an alternative to those heavy goggles.
thebigron
02-05-2003 18:36:39
 Re: Re: Re: Welding goggles elastic woes.... in reply to Matthew , 02-05-2003 18:02:13
You might try asking the wife for some elastic from her sewing basket. It comes in different sizes, strengths, and even colors.
ripper
02-05-2003 18:29:02
I like the goggles with the ratchet band not unlike on a hood.
