Riding mower
Ed
02-05-2003 09:33:02
My MTD riding mower turns over slowly even with a new battery. All connections have been cleaned. I have been told that the starter may be "getting weak". How does a starter "get weak"??
MPK
02-06-2003 07:48:37
 Re: riding mower in reply to Ed, 02-05-2003 09:33:02
You could take it off and take it to a shop that does alternator and starter repair. They could check it and see what it needs if it needs anything.
Mac
02-05-2003 18:16:44
I would remove it from the mower and run a direct 12V, see if it is free. Then maybe dis-assemble it and check brushes, bearings. Look for shiny spots on the field or armature. Used compressed air(with goggles) and clean the unit. Some times heat plus age just gets to these units
Jim K
02-05-2003 16:33:15
Ed if one of the bearings gets worn to the point where the comutator rubs on the stator it will seem as though it is getting weak. take it apart and inspect the bearings and or replace them. if you let it go for to long it will eventually burn out.
Jim K
art
02-05-2003 13:18:08
a starter is a DC motor with brushes and they wear out also the bearings can get water in them look around for a used starter from a blown engine like yours.
