ShopMaster BridgeMill?????
DumOleBob
02-05-2003 08:22:16
Any thoughts, good &/or bad, on the ShopMaster ElDorado Bridgemill, 3 in 1 tool?
DumOleBob
02-06-2003 09:24:02
 Re: ShopMaster BridgeMill????? in reply to DumOleBob, 02-05-2003 08:22:16
Got that, but I'm not building rockets, and don't have the $ nor space for dedicated machines. So I guess it boils down to: Are these toys or what?
Thanks fellows!
kraig wY
02-06-2003 10:27:30
 Re: Re: ShopMaster BridgeMill????? in reply to DumOleBob, 02-06-2003 09:24:02
In reality it depends on what you want to do. When I got my first lathe I was in to building guns. My main concern was spindle hole size and distance between centers (I was using barrel blanks) because I need to cut threads/chambers and taper the barrels. I have a 12 swing so I can't turn brake drums. I also have a drill/milling machine. With this I can do hubs and rotors. Its all in the set up. 90% of machine work is in the set up. If the machine you are looking for will meet your needs, (present and future) then go for it. Only you know what your needs are.
Rod MI
02-05-2003 23:02:09
I'm with Tom on this
Tom
02-05-2003 17:21:46
I am not familiar with this machine. However the general opinion among those with experience is that these combination machines are a compromise. Them may work for light work/small jobs, but are nothing like having seperate dedicated tools.
