Rent one. If you buy one plan on having it recalibrated every couple years which will tack on $100. To make it worth having one you need to use it quite a bit. UNLESS you happen to pick up an oldie reasonably, then it could be worth it.Okay, things to look for, Weight. They shouldn't be light. Light means cheaper manufacture, not goo. Make sure it swings in all its axis smoothly, any binding when the stop screws are open is bad. Make sure the stop screws work well. If you're laying out a straight line, like a fence row you don't want it moving. Make sure the fine control screws work well with no binding. Cheap models have control screws that only go so far, then you have to open the stop screw, wind the control screw back, close the stop screw again and then fine control more, they'll drive you nuts. Good base, older sets are threaded so the whole bottom of the instrument threads onto the legs. Newer units have a threaded hole in the bottom that the legs attach to, the newer type is much more handy although the older ones can be had cheaper. Obviously check for any thread damage. Readability. Newer digital instruments are great for readability but may need more frequent adjustment. They'll also be very finiky about being out of level if your just doing something quickie and not worried about real precision. On an older analog instrument make sure you can read the numbers. If you buy an analog instrument go get one of those little keychain magnefying glasses, and keep it with the instrument. Ask me how I know... Oh, btw, my old man is a Surveyor/Civil Engineer. I spent a couple summers and winters on his crews as instrument man, rod man, and data collector. When I was little I spent alot of time holding the rod for him before his company was big enough for him to have real paid assistants. I like surveying and frankly if it paid the money I like I'd probably be doing it now...
