Frozen acetylene regulator?
BillWV
01-22-2003 10:40:44
Is it possible for an acetylene regulator to freeze? Or can a tank valve be bad? Since I got my tanks filled, the acetylene pressure fluctuates madly. Stored in an unheated barn, it has been cold since I got the new tank. It seems to be better if I warm the tank/regulator with a trouble light.
Thanks,
Bill
T_Bone
01-22-2003 17:36:34
 Re: Frozen acetylene regulator? in reply to BillWV, 01-22-2003 10:40:44
Hi Bill,
Acet pressure will be very low when the cylinder is cold, this is normal, about 250psi @ 70*f a full cylinder and 30psi @ 0*f or there abouts. If the out-put side of the regulator, the one for setting the pressure to the torch, is creeping above 15psi then your regulator needs rebuilt or a new seat as it's leaking.
Under normal cold circumstances, Acet could frost the cylinder like a LP cyl will as the gas is being used. A good all around gas pressure is 5psi Acetylene.
T_Bone
BillWV
01-22-2003 19:36:13
 Re: Re: Frozen acetylene regulator? in reply to T_Bone, 01-22-2003 17:36:34
T-Bone,
The output side isn't creeping up, it is fluctuating madly. I use about 4 psi generally when cutting. It is going to 15 or higher and then dropping back down. Warming the reg with a trouble light seemed to help it, and it didn't start doing this until I changed cylinders. Could I have gotten moisture or ice in the regulator? And what would I do about it?
Thanks,
Bill
T_Bone
01-22-2003 21:20:29
 Re: Re: Re: Frozen acetylene regulator? in reply to BillWV, 01-22-2003 19:36:13
Hi Bill,
Hard to tell from here but if you have another regulator I would try that, borrow one? If it does the same then something is not right with the cyl but it sounds like a bad reg problem. You can go to your gas supplier and he'll check it out for you.
T_Bone
Ray
01-22-2003 16:53:02
Bill
Make sure the tank is standing up NOT laying down. Leave it up for about 24 hours before turning on the valve. Acetylene is very unstable above 15psi. There is a mud like mixture inside the bottle to keep the gas pocketed (in bubbles)
Dont allow this compound to get into your regulator.
BillWV
01-22-2003 19:33:23
 Re: Re: Frozen acetylene regulator? in reply to Ray, 01-22-2003 16:53:02
Thanks, Ray. I did leave the cylinder upright for about 12 hours before I used it.
