Ammco hone needs stones
STEVEN H
01-20-2003 17:23:38
i am in need of stones for a realy old ammco hone, i chiped the stones on the crank of one of my tractors and need to replace before i give it back to my friend. dont know what modle so i have turned to ytmag. the hone is just over 14 1/2inch long, the distance from the outside of the stones is just over 4 inch the stones are 4 inch long 7/16ths inch across and 1/4 inch thick. the hone its self has two parts a drive shaft that is disconectable. and the main body is rectangular with a 3/8ths groove cut into each of the four sides in the grooves is screwed in two peaces of spring steel flat bar stock that ataches to the stones i hope that some one can tell me what i have and maybe where to get stones from.
JerePa
01-21-2003 20:17:38
 Re: ammco hone needs stones in reply to STEVEN H, 01-20-2003 17:23:38
This guy can put new stones on your holder (the part the stone was originaly bonded to) Dennis Michael @ 610-869-4713. Near Phila., Pa.
Dave Wis
01-21-2003 18:45:03
Try Goodson in Winona Mn. 1-800-533-8010. They have a lot of engine machine tool supplies and parts. Good luck.
STEVEN H
01-21-2003 10:32:37
thank you all i will try napa and clyender hones as well, if any one has more just let me know.
Dennis Benson
01-21-2003 09:36:09
Try this site.
Link
I was looking for some for an Ammco cylinder hone, and If I remember right, NAPA was what they told me at Ammco.
I would also try one of the part stores like Advance Autoparts.
Fred Kobs
01-20-2003 20:53:17
I think NAPA stones fit Ammco hones. Was long time ago but worth a call.
Earl S
01-20-2003 17:48:51
Just do a search for Ammco. I see they are still in business under another name.
steven h
01-20-2003 20:27:16
 Re: Re: ammco hone needs stones in reply to Earl S, 01-20-2003 17:48:51
i have, and i found a guy in al that wont talk to me so i thought you guys here would.
T_Bone
01-20-2003 21:12:57
 Re: Re: Re: ammco hone needs stones in reply to steven h, 01-20-2003 20:27:16
Hi Steven,
Have you looked at cylinder stones? That sounds about correct for the size. Depends on the grit.
T_Bone
