Valve gringer
Ted
01-19-2003 08:44:48
Found a listing for a Sioux valve grinder, 50.00 bucks. Anybody know anything about this unit? thanks Ted
JerePa
01-20-2003 09:01:14
 Re: Valve gringer in reply to Ted, 01-19-2003 08:44:48
Let me know the model number & I'll send you the sales info (if I have that one).
kevin
01-19-2003 12:10:26
dennis i got a sioux that i would sell not sure on how old it is works fine. got the seat grinder also with a real good set of stems lots of stones 1,100 takes it I,m in IL.
Dennis Benson
01-19-2003 17:43:39
 Re: Re: Valve gringer in reply to kevin, 01-19-2003 12:10:26
I don't need one right now, I'm saving up to buy a new Miller spot welder. I have the seat grinding drive, pilots, stones, holders, and dresser. I wouldn't mind finding the set that was used for cutting heads to install new seats, but Sioux hasn't made that since about the 1960's at the latest. It was portable, and hand operated. But then, I want to get the spot welder first.
Dennis Benson
01-19-2003 12:01:32
That sounds cheap. Most can be fixed. They did have wet or dry models, and some only had one grinding stone, for grinding the valve's face. I looked at a very old one, and contacted sioux, and they said parts weren't available for them any more. I have most of my experience on Sioux valve grinders, the ways would wear out, and cause the valves to chatter, like a corrugated face. You can check that by shaking the assembly that slides back and forth, and if you feel movement other than the sliding the ways are bad, and will either have to be turned over, if they haven't already, or replaced. In the shop they had to be turned over after about a year, and replaced after another year, then turned over after another year, then after another year we got a new grinder, and did it again. I could jhust stand there grinding and watch out the windows, or tell jokes, and know by the sound that the valves were done. If you don't use it for hours at a time day after day, but only a few times a month or so, it should never wear out.
