A T_Bone Question
Scott Green
01-14-2003 13:47:32
Actually , it's a question for anyone. I just know that T_Bone is quite knowledgable with this stuff. I myself like useing 7014 welding rod for most welding projects. I see 7018 on the boards quite often , but I don't like to weld with it. My question is: What makes 7018 rod so popular for home use. Is it because people get it free from work? I know where I use to work , 7018 was probably the rod used most for preasure vessle work. It seams like every welder had 7018 at home. Of course , I was never a certified welder. (My job was to prep the material for the welders.) Or is there something about 7014 that I'm missing? Just curious to see opinions.
BFO
01-14-2003 16:48:51
 Re: A T_Bone Question in reply to Scott Green, 01-14-2003 13:47:32
Once I bought a DC machine I gave away all my 7014's and never looked back. I tried a lot of different rods, and have settled with Lincoln Excalibur. I also like to crank up the machine and put down some nice beads with 7024 when I'm into something thick and can keep the joints in a flat position.
T_Bone
01-14-2003 17:44:36
 Re: Re: A T_Bone Question in reply to BFO, 01-14-2003 16:48:51
Hi Scott,
7018 is one of the most versitile welding rods there is. I can't think of too many weldments that can't be welded with 7018. Vertical up, pipe 5G and 6G( pipe on 45* with a restricktor ring 1" away from center weld) is easy to weld with 7018. 7018 Chemtron can certifiy with open root although not the best rod for such. The open root is made with Lincoln 6010(5P) then the cover pass with 7018. Once you get good with 7018 then the slag will peal off by it's self so you don't need to chip the weld or very little chipping between passes.
Even on large commerical projects I awlays used 7018 and 6010 for field work. I didn't need any other type of rod to carry around for 99% of my welding. After you run a few miles of 7018 you don't need to adjust your heat setting as you learn to manipulate the heat required with arc length and travel speed.
Now in a shop enviroment then it pays to have lots of choices as time can be saved with the correct welding procedure, electrode type, joint design.
7024 is considered a jet rod as it welds very fast and smooth but two position limited and lighter penetration than 7018. So it makes a great shop rod as you can rotate the weldments and in the field you can't do this as most welds are "in" position welds. I welded wear bars on a D8 tracks one time and used 7024 as I could rotate the weld joints to a good position each time.
T_Bone
