Hi Kevin, Scfm stands for standard cubic feet per minute. It is the volume referenced to standard conditions of temperature, pressure and humidity. These are 60 deg F (some say 68), sea level atmospheric pressure of 14.7 psia and 0% relative humidity (dry). Cfm stands for cubic feet per minute and, by itself, is meaningless for any compressible fluid such as air. It must be tied to some specific temperature, pressure and humidity to have meaning. The volume of air is extremely dependent on the level of pressure, less so for temperature and humidity levels commonly encountered. The ratings of air compressors can be confusing with varying practices by the manufacturers. Some ratings are extremely misleading, particularly those based on horsepower. It is somewhat difficult to compare different machines and be sure you have a valid comparison. Compressors are properly rated, IMO, based upon a throughput of air at the temperature, pressure and humidity existing at the actual intake opening of the cylinder. See link for some definitions. If, and it is a big if, you don't have any intake restrictions such as piping or filters and are at sea level with mild temperatures and low humidity, the compressor rating in "cfm" is very close to scfm. It is sometimes common to express that rating in scfm although that is not precise. A better term of "free air cfm" is sometimes used or implied but the best is intake cfm or icfm as the link indicates. For instance, the capacity of the same compressor in New York City would have to be derated by about 20% (as I recall) if it were to be operated in Denver, CO. This is due to the lower atmospheric pressure in Denver. An excellent "dream machine" size for a home shop is about 15-20 (i)cfm at a discharge pressure of 175 psig. This would equate to a true 5 hp motor drawing about 23 amps at 230 volts. It would include an 80 gal ASME coded storage tank, be two stage with an intercooler and, optionally, an aftercooler. It should also have a magnetic starter. Cast iron construction, low rpm (<1000-1100), roller bearings, and liberal cooling fins on non-siamezed cylinders are signs of a well designed machine that will last a lifetime. The typical price range for new equipment in this class is $1500-$2000. Quincy has a very good reputation for a quality product. Most manufacturers in this competitive 5 hp category have a couple of different quality levels (and price levels to suit). Make sure you compare apples and apples when price shopping. This applies not only to different manufacturers but also to different machines by the same manufacturer. A 7.5 hp machine with no mag starter at $700 is NOT in the same ball park, performance wise, as the machine noted. No such thing as a free lunch :o). Rod
