Which generator to buy?
John G
01-11-2003 18:24:09
Anyone with experience running portable AC generators? I am looking for a reliable 5500 watt, and a brand on which I can get parts and service. I have a Homelite currently and am very unhappy with performance and durability and the lack of available service.
Keith Alexander NNY
01-18-2003 21:53:40
 Re: Which generator to buy? in reply to John G, 01-11-2003 18:24:09
I ended up getting a 4500w Generac during the ice storm of '98. Love it. the engine is made by generac and has pressure lube and overhead valve. Yery comparible to a honda. About 8 gallons in 24 hrs 1/2 - 3/4 load. Put 240 hours on it and all I did was change oil every 24 hrs. After event I put new plugs and an air filter on it. Run it every other month on a 1000w quartz light for 15-20 min. Also use stabilizer in fuel.
John G
01-13-2003 17:44:34
Thanks for all the great information everyone has shared on generator purchasing. This helps me a lot. I continue to be amazed at how few service centers are available in our area (N.C.)and how little they know about repairs.
Tim B
01-12-2003 20:39:22
John,
Check out www.mayberrys.com they are a power tool dealer in N.J. I bought a 3kw very quiet generator from them two years ago. The local dealers in Mass. couldn't come close to the price I got on that machine. Despite the $100 +/_ shipping fee, I saved over $300 buying from them (with savings on taxes, of course).
rg
01-12-2003 17:36:06
I have a coleman and I am unhappy with it. I bought it new at a good price but if I had to do it again I would spend the extra money and buy a Honda. Any that I know about are very reliable and just won't die.
Don LC
01-12-2003 10:23:55
I won't buy any small engine powered equipment unless powered with ----Honda , Kohler or Onan....
Wee Willie
01-12-2003 04:55:53
John G, I have a brand new one for sale. 5500 watt, Honda engine, 1 year factory warranty. I am a contractor and I thought I needed it for a specific project but it turns out I didn't. I'm selling it very very reasonable. If you are interested contact me and I will send you some pictures. [email protected]
Scott Green
01-11-2003 21:26:41
Hi John , You won't go wrong buying a Honda or yamaha generator. They are the best on the market when it comes to portable generators. Stay away from Colman. I've burnt up many of them in the past. Homelite is another cheepie , but better than colman. I've burnt up a couple of homelite also , before I got smartened up. When it comes to generators , you get what you pay for. I'm going to send you a site to look at. It will tell you all you need to know. I'd post the link here , but I'm not shure how to. So I'll send it to your e-mail address.
Check Out Northern Tool
01-11-2003 20:52:02
check out northerntool.com they have "Northstar' generators with the Honda engines that are so loved.
Scottey841
01-11-2003 20:37:33
Check into the Honda generators. Great engines. We have a 5000 watt one at work that is 13 years old and it always starts.
fredo
01-11-2003 20:20:37
if you are going to be using it on a furnace that has glow plug start you will need a gen. of about [10 kw] or it wontstart furnace. i could not start my sons with [7.5 kw] gen.
fredo
Scott V
01-12-2003 18:42:03
 Re: Re: Which generator to buy? in reply to fredo, 01-11-2003 20:20:37
Your generator needs to be grounded.the glow plugs need a good ground or they are eratic on starting.I learned that from my hvac friend.
Bob
01-12-2003 07:54:43
I can't imagine that a glow plug start furnace would require that much power to start. Ours worked fine using a 5KW unit last winter, and we ran it for almost a week that way.
Mac
01-12-2003 08:50:27
 Re: Re: Re: Which generator to buy? in reply to Bob, 01-12-2003 07:54:43
I was wondering about the same thing, I have a 5kw unit also.
Dick2
01-11-2003 19:25:29
AZ DOT had small generators with B&S engines in the fleet that weren't being used because they were so hard to start. I purchased Honda generators of various sizes from 1000 watts to 5500 watts and the crews used them a lot because they were reliable and easy to start.
Kelly C
01-12-2003 09:44:58
 Re: Re: Which generator to buy? in reply to Dick2, 01-11-2003 19:25:29
What is Honda doing that Briggs cant?
I think people are comparing Briggs bottom line engines with Hondas.
If you Take a top shelf Briggs that is in the same price range as the Hondas you would get the same service from it.
We had done the same for years. Buying 2 1/2 inch pumps with 3 1/2 hp briggs engines. Payed about $160 each and went through many motors.
We are now buying the Honda ones they are good but cost 3 times as much.
Hayman
01-12-2003 11:21:59
 Re: Re: Re: Which generator to buy? in reply to Kelly C, 01-12-2003 09:44:58
Honda generators are GREAT !
