Brad / finish nailer
mwkellner
01-10-2003 08:42:39
What is the difference between a brad nailer and a finish nailer, applications etc. I know that this is a simple question, but I don't know. Thanks for educating me (again). -- Martin
ben
01-13-2003 05:49:16
 Re: brad / finish nailer in reply to mwkellner, 01-10-2003 08:42:39
Maybe a little clarification. A brad nail is usually considered a 16 or 18 gauge nail, they come in lengths from 5/8 to usually 2 in. A finish nail is considered 15 gauge for slightly heaver work, it doesen't mean you can't swap one for the other depending on type of wood and application of your work.Hope this helps.
walt
01-10-2003 18:49:52
Brads are normally for furniture. Finished nailers are for house trim/doors/window casing, etc..
JohnnyB
01-11-2003 16:08:31
 Re: Re: brad / finish nailer in reply to walt, 01-10-2003 18:49:52
A brad nailer is usually a small diameter pin about 1/2" - 1 1/4" long for nailing small moulding that is pretty thin such as screen moulding @ 1/4" thick. A finish nail is normally 1 1/2" to 2 1/2" long nail and used to fasten thicker pieces such as 5/8" - 3/4" used in nailing casing, baseboard and plywood cabinet boxes together. Did you have a particular application that maybe we could help you with ???
mwkellner
01-13-2003 09:03:56
 Re: Re: Re: brad / finish nailer in reply to JohnnyB, 01-11-2003 16:08:31
Thank y'all for your respnses. That is just what I wanted to know, and I knew this would be the place to get it. I'll holler back next time I don't know something. -- Martin
