Looking for spline stock
Andy
01-09-2003 19:44:50
I am trying to fix a hub with worn out internal splines. I would like to find a piece of spline stock,(7"long) bore the hub out on a lathe and weld in a new splined insert. It is 2.5" resessed,(female) 6 spline. I can get 10 and 16 spline can't find 6. Anyone know of a supplier that handles this? I tried a few machine shops and no one cuts internal splines localy. Thanks for any input, Andy
jake
01-10-2003 06:47:51
 Re: looking for spline stock in reply to Andy, 01-09-2003 19:44:50
ggmfg.com has any thing needed for the job. Some times they will give you a local dealer. Make sure the pin hole and locking groove are done already, these shafts are hard.
mj
01-10-2003 17:08:31
 Re: Re: looking for spline stock in reply to jake, 01-10-2003 06:47:51
I can't get a site to come up with 'ggmfg.com' as in 'page not found", "page does not exist". Is 'ggmfg' correct?
jake
01-11-2003 21:56:48
 Re: Re: Re: looking for spline stock in reply to mj, 01-10-2003 17:08:31
third party image
I'll try to get the link right, www.ggmfg.com is correct.
jake
01-10-2003 06:44:10
third party image
ggmfg.com has any thing needed for the job. Sone timed they will give you a local dealer. Make sure the pin hole and locking groove are done already, thes shafts are hard.
Slowpoke
01-10-2003 00:13:56
I'm not sure of the diameter you want but I think a lot of tractor ptos are 6 spline, and you can get female drive shaft parts to match. Try a farm store, dealer or tractor graveyard.
kraig WY
01-09-2003 22:21:42
If all else fails get a broach cutter and make one. You can get a machine shop to make you the right size cutter.
Heat Houser
01-13-2003 14:24:41
 Re: Re: looking for spline stock in reply to kraig WY, 01-09-2003 22:21:42
A broach is very expensive to have made. Basically a broach is similar to a thread tap but instead of twisting it in, you get a large press and push (or pull) the broach through. The broach has teeth that start shallow at one end and are the finished spline size at the other with intermeadiate size teeth in between. Each tooth cuts out a sliver of metal as it is pushed through.
Larger broaches can cost up to 18-20 thousand if you get into larger sizes.
