Vat tanks
Pete Hall
01-09-2003 04:45:17
Does anyone know how machine shops vat and boil engine blocks?Is acid ,steam,air,or what else is used?
Any info would be appreciated.
Pete
Earl S.
01-09-2003 08:20:41
 Re: vat tanks in reply to Pete Hall, 01-09-2003 04:45:17
Pete, There are 3 basic ways we clean heads& blocks now. The hot tank , spray washer, heat and burn oven system, I personally like the hot tank for diesel, the spray wash for every thing else. The cleaner we us is a caustic soda for cast iron. YOU CAN NOT USE ON ALUMINUM. The aluminum we use a non foaming soap.The law requires you to have the solid waste removed by licensed waste management.Example (Safety Clean)The water you can skim the oil off and use over on clean out.Water temp is usually 140deg. to 170deg.I can explain the oven system if you need to know . I hope this helps. Earl
