Propane heaters
Doug Rogers
01-07-2003 11:38:54
I have a Remington "bullit" type kerosene heater. I have seen a lot of discussion here about using Kerosene in place of diesel or vice versa. Can you use diesel in these type of kerosene heaters safely and without ruining heater?
Ben in KY
01-07-2003 16:01:27
 Re: propane heaters in reply to Doug Rogers, 01-07-2003 11:38:54
I have used diesel in my torpedo. Works fine just stinks a little bit more than kerosene. Where are you guys at anyway. Kerosene is 1.49 here and diesel is just a little cheaper, unless I get the farm stuff and it stinks quite a bit more than standard road diesel. Higher sulfer content I guess.
Slowpoke
01-08-2003 21:34:22
 Re: Re: propane heaters in reply to Ben in KY, 01-07-2003 16:01:27
Northern Calif. Kero is $2.15/gal at the gas station, #2diesel is $1.65. Central Calif. diesel is $1.49...but the weather is nice.
TimV
01-07-2003 15:31:43
I have a 35,000 BTU Redi-Heat, and according to my owner's manual, Diesel is an acceptable fuel. I have never noticed any difference in odor, and it's definitely cheaper to run, particularly if you use off-road diesel.
skinner
01-07-2003 15:10:09
I do it all the time and I haven't had a problem. No smoke and a little smell but no worst than it was with Kerosene at three times the price!
JerryU
01-07-2003 12:18:05
According to the directions you can. I never have since people I have talked to say the diesel or fuel oil stinks worse than kero. Will be interested to see what others have done.
JU
fujioko
01-06-2004 16:58:12
 Re: Re: propane heaters in reply to JerryU, 01-07-2003 12:18:05
I just ran out or Kero in my torpedo, I think I'll try a few gal of diesel. Certanly cheaper.
Kero = $1.80/gal in Michigan
